it is ok provided the joint is suitablly enclosed and that all cables remain in safe zones (remember if a joint is hidden then it doesn't form safe zones arround itself)
Just how many temporary lights do you need in your kitchen - it appears there are eight that show in the photo alone
I can't for the life of me figure out that wire through the wall, and up into a hole in the ceiling.![]()
Your posts baffle me. You are happy to discuss the pros and cons of 12V vs 230V downlights
Looking at your photos:
The back box seems to have 6 inches of plaster around it. Poor workmanship.
You seem to have a cable running up the wall then across the bottom of your ceiling and into a hole. Did you mean to do this?
What are you feeding with 25 cables?
Have you decided to rewire your house now, in addition to the kitchen rewire and board change. You do realise this makes you responsible for the whole of your installation and requires an EIC.
Why have you used yellow crimps? They are for 4-6mm² cable. Insulation tape isn't a good idea too. Can you not pull back to where the wire goes and connect a new piece in?
No I cannot pull back to bathroom light & replace the whole cable, as to do so would mean chiping off some of the wall tiles in the bathroom, to replace the cable. (the bathroom is a single storey extension, off of the kitchen, on the back off the house)
Why is insulation tape not a good idea![]()
Cos it dries out and falls off, or can leave a horrible gluey mess. All connections should also be made in a suitable enclosure.
Why did you use yellow crimps?
There is usually more than one way of going about a job, I take it the wire goes up the wall inside the bathroom in a safe zone? Is there a void above the bathroom? Can you feed a new piece of cable via an alternative route?
