D
Deleted 100157
I currently have two lights controlled by two switches, one light and switch in the hall and the other light and switch in an area becoming a cloakroom and laundry. I need to remove the switch in this area as I realise it is not allowed to be in a bathroom area. Unfortunately this is the master switch and I do not have access to the secondary hall switch cable to run it directly to the lights.
The only solution I can think of is to remove the master switch faceplate in the new cloakroom, connect the wires using small connectors as necessary within the existing recessed single gang box and replace the switch with a blank faceplate (so the join is accessible). I would rather remove it completely but can't see how this will be possible whilst keeping the hall light and switch working. The question is, am I allowed to have a blank faceplate within Zone 2 of a bathroom and if so are there any special blank face plates or connectors that are required.? Can anyone think of another solution?
Thanks for your help.
Dave[/b]
Dave[/b]
