Dear all,
I've seen this covered on other, older threads, but don't feel a full explanation has been offered around what is compliant with the regs, and what isn't.
I would like to hardwire a two-gang trailing socket in place of a surface mounted two-gang switched socket that is on our 'downstairs sockets' circuit with a 32A MCB and a 80A/30mA RCD. The reason for this is that it is hard up behind a sofa and impossible to use with the room configured as is. It's an old stone cottage with few sockets. I would use 2m of 3-core flex, which can be 2.5mm2 (the same as the T&E on the existing circuit).
It seems to me this is no different than repositioned the existing socket with 2m more of T&E. Would there be any need to add a fused spur unit? The only issue I can see is a mechanical one, if the socket was tripped over/yanked. I'd imagined using a blank and one the punch outs with some sort of strain relief clamp to mitigate for this.
Looking for understanding about a)the regs and b)any safety issues about my proposal.
Thanks in advance.
Thanks in advance.
