Some of the regulars might like to see the Electricial Safety Council's report on downlighter safety at http://www.voltimum.co.uk/news/1336...ownlighters---Can-they-be-a-fire-hazard-.html
Yes. Yes they are.Are downlighters a fire hazard?
And the intumescent cylinder enclosing the lamp doesn't get extremely hot?
It's incredible just how many people fail to see that 1.a fire rated downlighter is just as likely to start a fire as a non fire rated one.
2.b]There is no reason to fit them in a non fire rated ceiling,[/b] 3, and all it acheives is to increase the final bill for your customer.
How does a "fire proof" luminaire, with the same ventilation characteristics as a regular one (obviously needed to stop the lamp from overheating) but which contains a material designed to intumesce when temperatures reach those which mean a fire has started below the light stop them from causing a fire in normal use?1. Dont agree --Reasons already given.
About the same price as ignorant superstition?3. What price Safety ??
BAS.....your such a tease !
Fire rated downlights are intended for use with Aluminium reflector lamps which are designed to throw the majority of their radiated heat downwards and away from the luminaire, leading to a reduced temperature to the rear surface...[ as previosly stated ,however,there is a drawback here with elv lampholder luminaires ] . The same cannot be said for standard downlights as the back of their lamp is prersenting a higher temperature to its surroundings. [ more so if dichroics or GZ10s are fitted.]
