Bricklaying on your own
I'd enjoy mine more if I was better at it. I think the whole back of this house will need to come down at some point, the mortar seems rotten.
If you look at the first and second images above you can see the bricks I used to weight the tops of the headers to prevent them from tipping forwards. Bloody pain!
Before.........
After.......(spoiled by an uncaring plumber:sneaky:).......
You’re worrying me now, because I did a soldier course (albeit a short one) and used a line like normal and nothing tried to tip forwards. That was on one of the black catnics with a flat edge at the front. However later when I used a different lintel with a downward sloping front lip, I had a mare with bricks wanting to tip forwards and it wasn’t even a soldier course
You can always use a straight piece of batten wedged between the jambs, which catches the edge of the bricks and you can also mark the gauge on.
I'm doing another today, i bedded the lintel in the dark last night.
Don't forget the cavity tray and weep vents. The WV's and tray just makes it that much harder to do.
The one I did in the dark looked better but I had a brick left over :LOL::LOL:
Thanks, I'll go and get some (y)
Do I still use the plasticiser with it?
It'll probably say on the bottle whether it's a plasticiser too. Covering it up is a good call - amazing how as low tech as a blanket can be sufficient to keep just enough warmth in the materials to stop the mortar freezing as the temp drops below 0. If it's sustained, it won't help, of course.. Paying 20p an hour to run a fan heater might be possible in the right conditions too (probably not this case tho), though generally a close eye on the weather forecast and not laying when low night temps are forecast is the easiest solution.
windfinder.com has some pretty good localised weather reports and forecasts. Beware: don't go to windfinder.co.uk - one of those "let's find a popular .com and buy the .co.uk version then load it up with viruses" **** sites
It said not to use with other additives but I did add a bit of Feb, it curdled like putting milk into coke so I did it again with just the frostproofer.
