- Joined
- 22 Jan 2007
- Messages
- 24,617
- Reaction score
- 3,710
- Country
We are causing it so, no it wouldn't.It would all be happening if we wasn't here.....probably
Don't believe youWe are causing it so, no it wouldn't.
Well we dont know so still probablyBut not at the same rate, and that is the issue.
No probably about it
Don't careDon't believe you
Anything? Anything at all to back that up with ?Don't believe you
DittoDon't care
Well, we do.Well we dont know
It's not the rate if change either, you really have not been paying attention have youSo if the rate of change is the issue, what does science, and common sense, say about why ?
The rate of change is the only part that is important.It's not the rate if change either, you really have not been paying attention have you
That is not what the debate is about - do keep up.The rate of change is the only part that is important.
Don't believe you
Yes it it. Rising fast because of us.That is not what the debate is about - do keep up.
You can try and cut down the debate as much as you want, but the facts remain.That is not what the debate is about - do keep up.
Well that is a major part of the climate doomers argument, so we agree on that oneClimate change has always happened and it is misleading to try and pretend that change is new and not natural.
Nope evidence shows it has happened before and faster but that info is not widely talked about because it goes against the man made narrative. And its the amount that man is responsible is what people are questioning in the debate - they believe it is vastly exaggerated, which it needs to be if you want to raise some nice tax out of it.But it is very misleading, and wrong to deny the rate of change recently, compared to any point in history, and suggest that man is not responsible.
I came across this, very sensible, and rational post in a newsgroup, posted by someone using the name 'Indy Jess John'. I hope he doesn't object to my reposting it here...
'I did a bit of digging a few weeks ago, and I discovered that the global warming claim for CO2 is because it blocks certain wavelengths of infrared from escaping into space. The same source of information also pointed out that water vapour also blocks a range of wavelengths of infrared, spanning and a bit wider than the range that CO2 blocks. There is many times as much water vapour than there is CO2 in the atmosphere. It varies by location from almost zero across the polar ice to maxima over rain forests, but the global average is at least 10 times as much as CO2. So even if the amount of CO2 doubles it would make only an insignificant contribution to global warming yet it would considerably improve crop yields.
The reason why CO2 was made the villain is because humans can do nothing about water vapour but they can be blamed for CO2; and that power allows governments to impose "green" taxes or legislate controls on behaviour and have the mugs who pay for it happy to do so to save the planet.
