- Joined
- 11 Jan 2004
- Messages
- 47,054
- Reaction score
- 4,072
- Country
The OP has checked the "loose ends" and has no continuity, so I suspect a break.Yes, ok, but with all those wires at the switch apparently doing nothing, just thought it was a bit early to be lifting floorboards - although we do know a bit more now.
As there is no neutral at the switch and only one twin and earth at the ceiling, there must be a junction box or joint between the two.
UNLESS....one of those cables with their black conductors in connector blocks in the switch back box is a switched feed up to the hall light. But if so, you'd expect continuity on the red between the ceiling and the switch.
