A couple of cases for discussion, where I have had very serious concerns about work done by obviously qualified and certified gas installers.
1. A domestic install, where a BG engineer installing an appliance had attempted to solder a chrome gas pipe into a gas chrome gas fitting, without making any attempt to remove the chrome. The joint was held together by nothing at all and very obviously leaking.
2. A commercial install of a combi gas boiler, replacing a heat only, in a small shopping centre - a place where kids often hung around at night, judging by all the graffiti and vandalism. A larger pipe had to be run all the way from the outdoor meter at the rear of the premises, rather than finding a secure route from meter to the boiler, or at least running the new pipe out of reach, the installer had run the 25mm pipe along the side of the building, an regular access corridor to the centre and just one foot up from the ground. It defies common sense that anyone would think it safe to run a pipe in such an unsafe manner.
Both no doubt had the necessary certifications, so I suppose that makes it OK?
