Does this quote sound fair?
5 Jan 2006
London
Supply and install the following:
1 x 6-way MK Consumer Unit with 63A DP Main switch, comprising of the following:
2 x 32A RCBO'S.
1 x 16A RCBO.
1 x 6A RCBO
Install main equipotential bonding to Water and Gas services.
Issue Electrical certification.
Notify work to building control.
£450.00
Whadda ya reckon?
I am based in SW London and it is a ground floor 2 bed falt.
Ta
It's not outrageous. Much depends on how easy/difficult it is to run the bonding to the services. If you think it's too much, get a second quote, but bear in mind that to fit a new CU requires testing of the whole installation. Therefore, there should be some contingency for problems which could arise, particularly if there was not previously any RCD protection. Plus a fair chunk of this quote is materials - RCBO boards aren't cheap.
Looks like a bargain if it includes a PIR on the existing circuits that will be connected to the new CU. Does it?
Liam
I would have a bigger board so as to give you room for expansion. No spare ways is short-sighted.
I'd also up the DP switch rating to 100A, if the new board does not have one.
if i were doing the job i would estimate as follows;
12mod fuseboarosd £40
rcbos £160
bonding water gas materials (depending on length of 10m used) £30++
new 25mm tails +16mm ec £10
full test and inspect of circuits included
labour £200
total: £440.
pretty good estimate.
carl
Liam
If PIR is a check on existing ciruits, then yes.
At present, there is only a cooker circuit, socket ring and lighting circuit, so only 3 fuses in the current boad are used.
I cant really see adding any more seeing as all the wiring is laid under a concrete floor.
