Clearly wrong.
Clearly wrong.
I would say that "Neither Henry nor Hoover are anything to do with each other." is just plain wrong. Acceptable (correct) alternatives would presumably include:Double negative to my mind (well, not a conventional double negative, but I'm sure you know what I mean!)
Curious as to why?I remove and destroy theseon a regular basis![]()
Specifically the plugs and sockets safety regulation requires most appliances (there are a bunch of exceptions/loopholes) to be supplied with a 13A plug. An approved converter plug that is fitted to the foreign plug and requires a tool to remove is an acceptable alternative. An adapter that can just be unplugged from the foreign plug is not.Correct, the law & regs does not forbid them, but they are not supposed to be supplied with new kit in lieu of a proper plug.
I would say that "Neither Henry nor Hoover are anything to do with each other." is just plain wrong. Acceptable (correct) alternatives would include:
Neither Henry nor Hooverareis anything to do with the other.
and
Henry and Hoover do not have anything to do with each other.
Fair enoughNo, the correct usage is either
either ***** or
or
Neither ***** nor
Agreed - I missed that.Neither Henry nor Hooverareis anything to do with the other
I have found them to be unreliable.Curious as to why?
Correct.Specifically the plugs and sockets safety regulation requires most appliances (there are a bunch of exceptions/loopholes) to be supplied with a 13A plug. An approved converter plug that is fitted to the foreign plug and requires a tool to remove is an acceptable alternative.
Debateable, basically our regs state something like [this is not supposed to be a quote from regs] - or complies with regs applicable in other member states.An adapter that can just be unplugged from the foreign plug is not.
Anything purchased outside the UK is totally excluded from UK regs or law and I see no way of changing that other than banning anything that is not type approved.I have no idea how this interacts with EU law though, especially if the item is sold and/or shipped from outside the UK.
Clearly wrong.
You should have rejected it as not suitable for use in the UK.I ordered it online but it was sent from Europe hence the EU charger. I assumed it would have a UK plug but sadly not. I've found a compatible UK charger available online but would it be possible to use a Fcu with this? It will be wall mounted so would be tidier if possible.
Why do you want an FCU?I've found a compatible UK charger available online but would it be possible to use a Fcu with this? It will be wall mounted so would be tidier if possible.
Whilst the purchase is clearly outside of the scope of UK regs/law, we surely can (and do) have "regs/law" about what can (and cannot) be imported into the UK, don't we?Anything purchased outside the UK is totally excluded from UK regs or law and I see no way of changing that ...
Doubt if they'd be capable of controlling personal imports.Whilst the purchase is clearly outside of the scope of UK regs/law, we surely can (and do) have "regs/law" about what can (and cannot) be imported into the UK, don't we?
Kind Regards, John
Recently I purchased 7 Ubiquiti units, 4 from UK which all had a UK IEC lead supplied by vendor in addition to the Shuko lead in the package, and 3 from Germany, 2 had UK leads as standard [in the package] and the 3rd had no lead at all as stated in the Ubituiti specs/documents.Doubt if they'd be capable of controlling personal imports.
