How long does concrete need to dry before I can lay tiles?
13 Apr 2011
Leicestershire
As the title says really; How long does concrete need to dry before I can lay tiles on it? The concrete and screed together are 150mm - it was laid 8 weeks ago.
Rules of thumb are:
1) I day per mm
2) 1 week per cm
3) 1 month per inch
Take your pick or get it accurately measured for your circumstances. If you do a search on this forum you will get the correct humidity figutres.
Rules of thumb are:
1) I day per mm
2) 1 week per cm
3) 1 month per inch
blimey lot off variation :D like the weather i suppose
21 weeks
15 weeks
or 24/26 weeks
Allow 1 day per mm thickness but a minimum of 28 days which is the time it takes for the cement in the concrete/screed to fully chemically cure.
The reason I ask is that I was aiming to move into the house at the end of October and wanted to lay the tiles on the floor before moving in - which would mean the floor would have had approx 13-14 weeks drying time. Do you think I'd get away with it? Will it have any adverse affects if there is moisture trapped under the tiles as a result? Really don't want to move in and be walking around on concrete floors for another 3 months! :(
A friend of mine was in a similar situation and laid the tiles......................... which came off in the following months.
Is this a new-build ? If so ask developer and let us know his reply as I would be curious to know what they say.
It's a 1960's build - the backfill in the original floors wasn't packed down and over the years it settled leaving voids under the concrete. As a result the concrete sank and we had to rip the floors out and start again. So it looks as though I'll be enjoying concrete floors til xmas then! :cry:
Look on the bright side. At least you won't have to get the Christmas tree needles out of the carpet :mrgreen:
