I've just had a new kitchen fitted in the house and while doing some electrical work, the spark basically condemned the existing wiring going out to my detached garage.
It seems the previous owner has used ordinary an extension cable to take the power from the CU in the house, out to a CU in the garage. The good news is that he run it plastic ducting so replacing it will not be too difficult.
I have bought 12m of 6mm 3 core SWA plus two glands, but I have realised I have no idea how to fit the glands! Does anybody know of a online diagram which would explain how it all fits together?
I think I'm going to need to fit two adaptable boxes and have T&E tails back to the respective CU's...I assume the T&E tails will need to be 6mm as well..
At present, the existing ducting comes up in the standard external meter box on my house. Would it be ok to fit an adaptable box in there? I had a chat with the Scottish Power spark who replaced the meter, and he said it was OK....
Finally, can somebody explain the earthing protocols involved?
At the meter box end of things, can I pick up an earth in there or do I have to get an earth back to the house CU?
At each end of the SWA, do the earth core and strap linking the steel armouring both go back to the same earth point or do I only need to worry about terminating the earth core?
At the garage end there is a local earth via an earth spike and earth cable..
Do I need to reconnect this up if I am picking up an earth from the house? BTW, the house is not a PME installation according to the Scottish power spark...
Thanks in advance,
Peter
Thanks in advance,
Peter
