B
billy bob
htgeng, I did not think that the plastic flue pipe from Atag was sutiable for external use, I had been told that it is not UV resistant, and would need to be painted with a protective paint if it was to be used outside
Not what GW show in their flueing guide, which I provided a link to earlier. Anyway the OP has been asked to check this a couple of times but hasn't done so - yet (daglesj!).ollski said:I think the flue extensions use the same terminals as on the plume management kits ie inside the pipe.
ollski said:I think the flue extensions use the same terminals as on the plume management kits ie inside the pipe. I can definitely see it on the higher one and presume it is fitted on the lower.
chrishutt said:Not what GW show in their flueing guide, which I provided a link to earlier. Anyway the OP has been asked to check this a couple of times but hasn't done so - yet (daglesj!).ollski said:I think the flue extensions use the same terminals as on the plume management kits ie inside the pipe.
billy bob said:htgeng, I did not think that the plastic flue pipe from Atag was sutiable for external use, I had been told that it is not UV resistant, and would need to be painted with a protective paint if it was to be used outside
.ChrisR said:How hard could it have been to have put those flue ends the same way round!?
htgeng said:Just wonder if that gas pipeline can support the 30cxi? Can you measure the rough length of the gas pipe and count how many bends there are!
daglesj said:htgeng said:Just wonder if that gas pipeline can support the 30cxi? Can you measure the rough length of the gas pipe and count how many bends there are!
Guesstimate length at around 40'+ with 6 bends.
