chrishutt said:Daglesj, I know you've got a lot going on with this, but you've neglected a few points.
1. You were supposed to post some pics of the condensate termination and other outside pipework. We might as well do the job properly...
2. I asked if you would put your email address in your profile, in case anyone wishes to contact you about this. You haven't... (as bad as Liam?).
3. It's been suggested a few times that this abortion of an installation should be publicised more widely. Links to this thread are probably wending their way around already, but we could be more systematic about it. Would you object to this thread being brought to the attention of the media?
As I said before, it's the white plastic pipe that runs from below the boiler and appears to pass through the wall lower down. Then where does it go?daglesj said:..whats the condensate termination? Then I'll post a pic of it.
chrishutt said:As I said before, it's the white plastic pipe that runs from below the boiler and appears to pass through the wall lower down. Then where does it go?daglesj said:..whats the condensate termination? Then I'll post a pic of it.
Also the PRV discharge pipe (15mm) which runs along with the condensate pipe initially and then joins a larger copper pipe (22mm) and disappears into the floor. This should eventually discharge externally like an overflow pipe. Can you find it?
Just? But knowledge of flues is absolutely central to gas safety. No excuses whatsoever for that. Twin pipe systems are inherently more dangerous since a flue pipe leak could mean CO in the bedroom (in this case) rather than just being sucked back into boiler via air duct as with concentric systems.rob884 said:its prob just a lack of knowledge about HE flues or flues in general thats escalated this problem.
Not for Keston boilers. They use standard 50mm MUPVC waste pipe. I reckon £25 would have covered your flueing materials. Did you consider a Keston?hteng said:Twin flues are expensive!
