    Dismiss Notice
I was considering Intergas for a boiler replacement but I think I’ll have to give them a miss.
Discussion in 'General Discussion' started by Motman, 6 Apr 2018.
  1. transam
    transam
    20 Nov 2009
    21,183
    Thanks Received:
    2,850
    Surrey
    Country:
    The most popular wall hung boiler sold in the USA for the last 5 years (?) is the Navien make ( South Korean) they are now in the UK market
    Daikin are also in the boiler market now.
    Another make I came across in the UK recently was Warmhaus (german made in Turkey afaik
    Or you could fit a Wolf boiler. Rumoured to be heating the Kremlin ?? apparently designed by a lady ?? If they are heating the Kremlin they must be reliable ??? minus 30 in the winter and the boiler packs up Putin cops the hump ? and the Wolf rep could find a couple of Kremlin Heavies knocking on his door in the early hours ;)
    • Like Like x 1
  2. SirGalahad
    SirGalahad
    1 Apr 2016
    5,701
    Thanks Received:
    157
    Country:
    So which one would you fit?
    https://www.furnacecompare.com/boilers/navien/reviews/
  3. transam
    transam
    20 Nov 2009
    21,183
    Thanks Received:
    2,850
    Surrey
    Country:
    never come across or seen a Navien . But they do have a massive manufacturing base ?? fairly new players in the UK ???
    A lot of boilers imported into the UK are specifically for the UK market ?
    Viessmann founded in 1917 still family owned ? the founder was rumoured to have been responsible for or designed the Crematoriums (gas fired) used for holocaust body disposal ???
    One of the biggest boiler manus for sales may well be ROC , Chinese manu , given the size of the Chinese market , (they are imported into the UK)
    Most boilers share parts from the same parts manu's . Grundfoss or Wilo pumps, sit, Honeywell, siemans gas valves ect ect
  4. transam
    transam
    20 Nov 2009
    21,183
    Thanks Received:
    2,850
    Surrey
    Country:
    Honeywell are probably responsible for more breakdowns than any other manufacturer ???????????
  5. Ihavenojob
    Ihavenojob
    7 Jan 2010
    5,642
    Thanks Received:
    967
    Chigley, near Camberwick Green, Trumptonshire
    Country:
    I'd keep it.
  6. securespark
    securespark
    11 Jan 2004
    33,195
    Thanks Received:
    985
    Country:
    I have a 1982 Ideal Mexico...
    Not very efficient but reliable.
    Would you keep that?
    If not, what would you replace it with?
  7. bernardgreen
    bernardgreen
    3 Nov 2006
    21,808
    Thanks Received:
    2,003
    Bedfordshire
    Country:
    Rated at 72% in a time when ratings could be trusted.
    As long as it is working safely keep it.
    • Thanks Thanks x 1
  8. Motman
    Motman
    27 Feb 2017
    3,453
    Thanks Received:
    393
    Essexshire
    Country:
    So, I’m being advised to keep a 26 year old boilers and someone else is being advised to keep a 36 year old boiler. Just what is wrong with these modern efficient boilers?
    Only reason I’m thinking of changing mine is because it’s making a noise. I suspect it’s the fan. Can someone listen to this noise and confirm my suspicions.
    If it is the fan, is it a diy job or a gas safe engineer job? Is it worth fixing or is it time to scrap it?
  9. Bodgeitandleggit
    Bodgeitandleggit
    15 Jan 2010
    1,668
    Thanks Received:
    32
    Yorkshire
    Country:
    I had a ferroli combi and had problem after problem... about 8 years ago and it was a pain in the ass, decided enough was enough and spent hours looking at reviews ,least problems after care and all other info I could find and my decision was a worcester bosch greenstar 28i and get it serviced every year and i am more than happy with it. I would highly recommend these to anybody wishing to renew their boiler
  10. bernardgreen
    bernardgreen
    3 Nov 2006
    21,808
    Thanks Received:
    2,003
    Bedfordshire
    Country:
    Probably nothing seriously wrong with the boiler, the problem is the way they are marketed to the general public.
    Are they really that efficient ?
    The figures in the adverts are for a boiler in a test situation and are seldom achieved in a real life domestic situation.
  11. Motman
    Motman
    27 Feb 2017
    3,453
    Thanks Received:
    393
    Essexshire
    Country:
    A bit like the claimed MPG figures that car manufacturers pump out that bear no relation to actual mpg figures achieved in the real world?
  12. The Baker
    The Baker
    10 Jul 2005
    6,333
    Thanks Received:
    984
    Lancashire
    Country:
    The sound emitted is like the boiler is "kettling"
    I think I can make out the fan rotating but it does not sound unduly loud. All old fans make a bit of noise.
    If I am correct about the kettling this would indicate the heat cast iron heat exchanger is scaled up.
    In simple terms less heat goes into your heating and more goes out of the flue.
    I can not remember the flue temperature of you make of boiler but probably around 250 degrees C. Some one will correct me if I am to far out.
    Where as condensing boilers flue gas temperatures are considerably lower. Around 50/60 degrees C. So more heat is being extracted from each £1 of gas consumed.
    Any modern boiler is going to consume less gas than your existing appliance.
    If you buy a new boiler pick a manufacturer who offers a 5 years + warrantee, make sure the installation is registered with the manufacturer, make sure all paperwork is filled in and kept in a place you can find it, and have the appliance serviced annually.
    Tim
  13. Motman
    Motman
    27 Feb 2017
    3,453
    Thanks Received:
    393
    Essexshire
    Country:
    Tim
    Thanks. Thinking about it now, it only starts making that noise when it’s been running for a few minutes and warmed up plus I occasionally get air in the sealed system. Might be time to start looking for a new boiler!
  14. Motman
    Motman
    27 Feb 2017
    3,453
    Thanks Received:
    393
    Essexshire
    Country:
    Well, I've just had a reply from Worcester Bosch. Answers my enquiry very succinctly. I only sent the enquiry just over an hour ago. Now that’s what I call an efficient customer enquiry service. I’m sure they have their haters but I couldn’t have expected such a quick reply on a weekend. They're in the running for my business already.
    "Thank you for your enquiry.
    Based on the information provided the Potterton profile 60e boiler has an output of approx. 18kw and is a heat only boiler. From your description this has been converted to a sealed system. A modern equivalent would be the 18 RI regular boiler, this would allow you to continue to use the existing circulation pump (likely to have been sized to the property) and controls. This is a regular boiler that can be converted to a sealed system boiler.
    For further information on this boiler please use the link below:
    https://www.worcester-bosch.co.uk/products/boilers/directory/greenstar-ri-12kw-to-24kw
    With regard to system boilers the equivalent would be the Greenstar 18I system boiler. Please note this will already contain a circulation pump (15/70 pump) as well as an expansion vessel and pressure relief valve and gauge. With this option you wouldn't need your current pump/expansion etc.
    https://www.worcester-bosch.co.uk/products/boilers/directory/greenstar-i-system-9kw-to-24kw
    Please note we will always advise boiler choice is confirmed by a qualified gas safe engineer who can visit site and discuss with you what you require.
    Regards,
    Technical Support
    Worcester, Bosch Group
    Opening Times
    Monday to Friday › 07:00 till 20:00 Saturday › 08:30 till 16:00
    Telephone
    Technical Support › 0330 123 3366 ErP Helpline › 0330 123 3641
    Renewables › 0330 123 9229 Stoves › 0330 123 2445
    Commercial › 0330 123 0165
    Email
    Technical › technical-advice@uk.bosch.com
    Rewewables › renewable-advice@uk.bosch.com
    ErP› erp-advice@uk.bosch.com
    Video Call
    We can now offer video calls to compatible smart devices using Bosch Insight.
    Please call Technical support on 0330 123 3366 to arrange this service.
    Download Visual Support for iOS and Android."
  15. Ihavenojob
    Ihavenojob
    7 Jan 2010
    5,642
    Thanks Received:
    967
    Country:
    A big old beast, & very reliable. The model replacing it depends on several factors, one being that it could be on a gravity system at that age.The disruption would be great, so i would wait until you had to do any major work to the house (usually a new kitchen/bathroom) I dont install, only repair, so anything easy to work on is good, Ideal Logics are good, Worcester are a pain to work on but very very reliable & their back up is good.
Loading...
Share This Page
