Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
In gone days I used plumbers mait, but since a few years ago a good plumber introduced me to basin mate and mcalpine traps, I don't put anything there and never had a leak.
Thanks a lot guys also another question do I need to use PTFE tape when I connect the the flexi pipe from the tap to A cut off Vale 15mm or quarter inch .
I think they are flat faced the shut off valve hut not sure .
Then i have 15mm copper running from the isolation valve .
No, flat face against a flat face usually needs a fibre washer.
Use PTFE tape where there is a tapered threaded, where the seal is on the threads. No attempt should be made to seal parallel threads, the seal is formed elsewhere.
Use nothing on a compression joint where there is an olive, or at a pinch a wipe of Mait.
Another vote for plumbers mait. My tip, don’t need it in the fridge, use a drop of water and it becomes more pliable and find it doesn’t stick to my fingers either.
