    Dismiss Notice
plumbers mate vs silicone basin waste install
Discussion in 'Plumbing and Central Heating' started by movieman, 17 Jun 2021.
  1. movieman
    movieman
    27 Oct 2017
    50
    Thanks Received:
    Country:
    Hi all
    do you recommend to use plumbers mate vs silicone for the install of a bathroom waste. i've got a sprung slotted wasted.
    if you do recommend the plumbers mate do i need to buy extra / different washers
    thanks
  2. Sponsored Links
  3. Baths'N'Gas
    Baths'N'Gas
    31 May 2009
    136
    Thanks Received:
    36
    Lincolnshire
    Country:
    Silicone
  4. oldbuffer
    oldbuffer
    6 May 2010
    1,348
    Thanks Received:
    507
    London
    Country:
    1. Someone has to say it. Plumber's Mait.
    2. I use it:
    2a. Because it doesn't set, which means the waste can be removed in future without a crowbar.
    2b. The basin can be used immediately without waiting for silicone to dry. This means the overflow can be tested immediately.
    3. You shouldn't need any extra washers. However, I'm also a believer in using the "Basin Mate" rubber seal which:
    3a. Goes under the basin.
    3b. Comes with the necessary washer(s).
    3c. Stops the water leaking down the threads if the overflow operates.
    • Like Like x 2
  5. movieman
    movieman
    27 Oct 2017
    50
    Thanks Received:
    Country:
    thanks a lot mate that such a big help i think i can do it now
  6. picasso
    picasso
    8 Apr 2008
    10,532
    Thanks Received:
    2,627
    Essex
    Country:
    Another vote for the basin mate.
    • Like Like x 1
  7. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,555
    Thanks Received:
    1,921
    Hertfordshire
    Country:
    Basin Mate, all day long, quick, easy and no mess.
    Andy
    • Like Like x 2
  8. johnny2007
    johnny2007
    11 Jan 2012
    3,425
    Thanks Received:
    518
    London
    Country:
    Basin mate, no silicone
  9. aptsys
    aptsys
    16 Sep 2007
    1,837
    Thanks Received:
    146
    Country:
    Never had an issue with Plumber's Mait
    • Like Like x 2
  10. Sponsored Links
  11. movieman
    movieman
    27 Oct 2017
    50
    Thanks Received:
    Country:
  12. Harry Bloomfield
    Harry Bloomfield
    30 Dec 2018
    6,444
    Thanks Received:
    948
    Country:
    • Like Like x 1
  13. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,555
    Thanks Received:
    1,921
    Hertfordshire
    Country:
    • Like Like x 1
  14. John the plumber
    John the plumber
    15 Oct 2020
    891
    Thanks Received:
    42
    Cornwall
    Country:
    Plumbers mait vote here too -Tip -Leave the plumbers mait in the fridge overnight the day before the job . (Stops it sticking to your fingers so much ) (y)
    Does my nut in when I get arrive at a job and see gallons of silicone everywhere all over the waste .:mad:
    (Plus it’s usually always on a Friday afternoon):cry:
    • Like Like x 1
  15. movieman
    movieman
    27 Oct 2017
    50
    Thanks Received:
    Country:
    Thanks a lot guys also another question do I need to use PTFE tape when I connect the the flexi pipe from the tap to A cut off Vale 15mm or quarter inch .
    I think they are flat faced the shut off valve hut not sure .
    Then i have 15mm copper running from the isolation valve .
  16. John the plumber
    John the plumber
    15 Oct 2020
    891
    Thanks Received:
    42
    Cornwall
    Country:
    No PTFE needed as it’s the rubber in the flexi that creates the seal.
  17. polesapart
    polesapart
    27 May 2011
    1,298
    Thanks Received:
    328
    Country:
    Silicone for me, judiciously applied, only where and when required and certainly not gumming up the threads.
Loading...
Share This Page
