Our secondary heat exchanger doesn't moveneither does the Intagases secondary heat exchanger
Fair enough
Now... must do paperwork
Fair enough- is yours a parallel or serial pass? One could argue a plate moves when it gets taken out for cleaning/replacing
Now... must do paperwork![]()
How do you know?...What is the measure?...Do you know every manufacturer employee?VC is about as unbiased as a manufacturer employee can be.
So, you consider the Vokera Vision recommended by a guy who fits nothing else and he has no problems but because people you don't know have alleged problems with the boiler installed by installers you don't know you'll look elsewhere?
That Vokera platform has been out nearly 7 years now, the waterblock (the bottom part) nearly 10. After this time the company are happy to give it 5, 7 or 10 years warranty depending on the spec and current promotions. If it's going in a loft you can plug in the BeSMART which gives you complete remote control of the boiler for around £125, including remote alarm notifications and reset of the boiler. Just about the only thing at the moment you can't do remotely is monitor system pressure, you'd need a higher spec model for that and remote filling. It's available in 25 or 30KW versions. Although it's competitively priced do not buy a boiler only on price.
Fans of the Intergas often display a tendency to exaggerate; far fewer moving parts in the boiler actually computes to 1, the diverter valve. The valve is necessary for positive control of the domestic hot water temperature and reduces the chance of a slug of very hot water when opening a tap if the boiler has been supplying central heating at a high temperature which can happen with the Intergas. Of course that can be mitigated by running the boiler cool continually when supplying water for the central heating. If you are in a hard water area the 12mm domestic hot water pipe diameter requires good anti-scale protection device. Less is more is the company slogan which is a puzzle as to why it costs more than many boilers providing more for less.
The next Intergas model is 122% efficient I'm led to believe and they've made 2 million heat exchangers each with at least 20 joints in each yet have never had a single failure; pretty interesting claims.
Atag; stainless steel heat exchanger, very tough but with 2metres of thin rubber gasket at each header end.
If you have good pressure and flow rate from the cold main into the house then a higher output boiler would reduce the time filling a bath but pointless if your mains isn't up to supplying what the boiler can produce, outputs of up to 42KW are available.
There are no perfect boilers, just find an installer you feel comfortable with and who is recommended to you because of his reputation and go with what he suggests.
I work for Vokera BTW.
Technically you could do it with a funnel and hose pipe. I started doing them with a BnPoo garden weedkiller pump thing. Just use my powerflusher now.
If anyone thinks a boiler can be 127% ( or 122% )efficient they are deluding themselves and their customers.I think the latest revisions have got it up to 127% efficient on the tests
Opinions about claims to have designed a boiler that is 127% efficient can only be negative.but I don't feel threatened enough to continually post negative opinions on other manufacturers products![]()
I think the latest revisions have got it up to 127% efficient on the tests but I don't feel threatened enough to continually post negative opinions on other manufacturers products![]()
Gotta take the fecker out first though![]()
