Removing an old fuse switch
25 Apr 2019
Hello,
We have an old fuse switch in our hall, its off and was once for the Alarm which has since been replaced. I want to cover the wall with those acoustic wall board jobbies but done want to cut the boards out around it as it will look bobbins. Can I remove the front and connect the wires into a terminal block and put a flush cover over the front so future folk will see there is something there please?
Ta
According to the big book the answer is - No. as there should be some visible way to indicate the presence of live cables.
EDIT: and then I read your question properly: if there is a visible electrical accessory then it is fine.
