- Joined
- 6 Sep 2016
- Messages
- 40
- Reaction score
- 0
- Country
Hi All,
Like the title suggests I am replacing my cooker with separate oven and hob.
I am after confirmation about the wiring required to install these safely please.
There is currently a cooker switch connected to a connection unit where the cooker is wired in. The breaker at the consumer unit is 32A. I'm not sure of the exact rating of the current cooker but it is a twin oven and ceramic hob (at least 8500 watt but I haven't included the top oven rating as I don't know it).
The new ceramic hob (Beko HIC64402T) is 6700 watt and the oven (Beko BXIF243) is 2300 watt.
My plan is to -
a) connect the hob directly to the connection point. The instructions say to use H05RR-5 5x 1.5mm^2 or 3x 2.5mm^2 cable - what exactly is this? This reference doesn't seem to bring anything up on Google?
The instruction manual shows the connection as one of the below.
I think the right option is what I would use? Can the copper bridge be an off cut of the 2.5mm^2 cable?
b) connect the oven to a 13A FCU and then to the connection point. The instructions say to use H05VV-FG 3x 1.5mm^2 cable - again what exactly is this?
The connection is simpler here, a single option with L, N and E.
Can someone confirm this is correct?
And explain the cable references to me please?
Thanks a lot in advance.
Doug
My plan is to -
Doug
