Replacing the Kitchen
3 Sep 2006
Kent
I have just started to replace the old kitchen, Last Saturday (22nd September 2007)
Here are some pictures of the old Kitchen
The Cooker Side of the Old Kitchen
The Sink Side of the Old Kitchen
The Sink Side of the Old Kitchen, With the fridge/freezer in temp. place
The old undercupboard lights (There were 4 of these under the run of wall cupboards on the cooker side of the kitchen
Plug for the 4th undercupboard light
Join in the cable feding the 4th undercupboard light
Close Up of one of the old undercupboard lights
Here are some pictures of what has been done so far in the kitchen
Some of the wall cupboards removed
The tall floor unit removed
Removing the two lots of old tiling
The old Bathroom light switch
The socket feding the fridge
The fridge cable
The fridge socket
The washing machine & tumble dryer socket
One of the 3 kitchen ring sockets
The old ring circuit wiring
Wiring the temp. Sockets
Close up of the temp sockets (From the top socket, Door bell, air fresher, fridge, washing machine & tumble dryer, back floodlight, radio, kitchen lights, cooker)
The house electric supply
The temp 110V kitchen lights
Holes in the floor filled up
The Temp. Kitchen in the dining room
The Boxes with the New Kitchen In
After the Kitchen is done the next job will be, to turn this covered courtyard into a Utility Room (When I am doing the kitchen electrics, I will run out the cables for the lights & sockets in the new utility room)
More Pictures to come later
Erm.... nice shots of plug sockets and disarray. :confused:
I'm sure you'll get comments when you post pics of the new kitchen. ;) Are you fitting it yourself?
Yes I am fitting it myself, I am doing the chasing for the new sockets & cables at the moment
Some More Pictures Of the Old Wiring
Cable Chase from the old Double Socket by the sink
The Old Hole from the Double Socket by the sink
The old chases from the Bathroom light switch
How NOT to Join a Cable
Close up of the Bad Joint
The joint in the 2 pictures above was buryed in the plaster, the cable with the joint in, goes to the bathroom light
The old hole from the Bathroom light switch
If you'd stop taking pictures and get on with the kitchen you could have had it finished by now. ;)
It will take a few weeks to do the kitchen, because all the electrics in the kitchen are being redone, & some of the pumbing in the kitchen will be renewed.
Also the only time I have to do bits in the kitchen are, Saturday, Sunday, Monday & Tuesday all day, & a little bit of time on Wednesday & Thursday Evening. As Wednesday, Thurday & Friday I am at college.
Nice project :cool:
Look forward to seeing more progress and pics etc
Here are some more pictures
The old electrics
The Join for the old lighting circuit (notice that the cpc's are just turned together)
The New electrics
The new electrical bits
The new back box for the bathroom light switch
The cables for the new bathroom light switch
The cable to the bathroom light
Cables to the bathroom light switch & the under cupboard lights cable
Half of the new cables (15 out of about 25)
Close up of half of the cables
Some of the joists for the new ceiling
The pipe for the outside tap
Socket & 2 downlights cables, above the new ceiling
New Ceiling joists
New cables to new bathroom light switch
Temp Supply to bathroom light
New ceiling
New ceiling
New ceiling
New ceiling
New ceiling
Cables for fridge socket & 1st under cupboard lights socket
All of the new cables
Socket cables
Under cupboard lights cables
The new joint in the cable to the bathroom light
The new joint in place
The joists for the ceiling, by the bathroom door
The finished ceiling by the bathroom door
The ceiling by the back door
Why have you used yellow crimps? They are for 4-6mm² cable. Insulation tape isn't a good idea too. Can you not pull back to where the wire goes and connect a new piece in?
No I cannot pull back to bathroom light & replace the whole cable, as to do so would mean chiping off some of the wall tiles in the bathroom, to replace the cable. (the bathroom is a single storey extension, off of the kitchen, on the back off the house)
Why is insulation tape not a good idea :?:
