I have now fitted the 4th replacement Shower pump, and am getting a bit pee’d off with this –so would appreciate some advice please and hope someone can guide me in the right direction please....
The shower was professionally moved in 2011 as part of a major refurb, and at that time it was fitted with a Salamander pump, a positive feed one with no pressure vessel on top.
This lasted about 6 years, at which time in order to get the pump to start the shower head had to be laid on the floor of the shower until it gave greater volume (then put higher up on the holder), but eventually this didn’t work any more.
I have reasonable DIY skills (I am of the generation that if you couldn’t fix your car yourself, you had to walk) and replaced this with a similar positive feed pump, a Salamander in 2017. This worked OK, but after a couple of years this also needed the shower head to be laid on the floor of the shower to get the pump to start. This one only lasted 3 years and gave up in 2020.
After taking expert advice, despite the position of the cold tank, hot tank and feeds implying that another positive head pump would work – but because of needing to put the shower head on the ground – I installed a Salamander CT60BU in 8/2020. This lasted 5 months. It hunted regularly, but decreasing after a week or two to not hunting any more – but one morning I discovered the pump being red hot and buzzing and clearly stuck although no one had tried to use the shower, so presumably it hunted but stuck. I turned off the electric and once it had cooled down, I turned the shower on and let it run for a while (to maybe free the pump?) and when I turned the electric on it restarted. In order to prevent this happening, from that point the electric to the pump the pump was turned off after use and turned back on before use. And two weeks ago, it wouldn’t start at all, being stuck and nothing would start it. This was deemed to be a faulty pump.
So I have just installed another Salamander CT60BU. This has been hunting, so to avoid a repeat, the electric is turned off after use. Although a pain, I know this shouldn’t happen – but I’m also worried this one will fail again….
Help please….?
In order to give as much info as possible, which I hope will help:
- all pipes are 15mm
- the cold tank is in the loft, and feeds vertically to the pump
- the pump is on the floor of the airing cupboard below the cold tank (standard height ceilings)
- the hot tank is in the airing cupboard and is raised, with the bottom of the tank being about 80cms above the pump
- the hot feed comes from the middle of the tank, and seems to be an Essex flange, and drops almost vertically to the pump
- the shower is on the same floor as the airing cupboard
- the shower is about 5-6 metres from the pump, on a far wall (I cant trace the pipe run, but am concerned that when installed in 2011 it involved a lot more 90 degree turns if taken from the position of the previous shower unless a new pipe was run?). There are no leaks.
- If the pump is not on, the shower head gets 3 litres per minute if temperature set to cold; 1 litre per minute if set to normal temperature but before its warmed up; 1 1/2 litres per minute when warmed up.
Could it be the Thermostat Compact Cartridge in the shower controls in the shower?
Should I leave the electric connected to the pump, to let it hunt and then stop?
Any help much appreciated,
Thanks,
Den
Help please….?
Thanks,
Den
