Yorkshire made chrome plated solder ring fittings, you just remove the chrome plate on the pipe where it enters the fitting, solder it as usual then wash the fitting with soap and water when its cool and it will be all chrome and shiny.
billplumb said:just to prove a point about using pushfit fittings on chrome pipe, i myself pressure tested a couple and did not blow off at 50bar hydraulic test. take it from me, john guest only advises not to use pushfit on chrome. don't just take the catalogues information as gospel put it to practice for yourselves. you wouldn't put your hesd in the oven and turn it on if they told you two CORGIMANN & CHRISHUTT!!!!!!
