- Joined
- 11 Jan 2004
- Messages
- 46,640
- Reaction score
- 3,889
- Country
but only do that if it's her birthday...
evidently . . . you're also too lazy to brush your own teeth adequately without mechanical aidTheOriginalSlimJim said:Come one.... im FAR too lazy for that![]()
FFS.TheOriginalSlimJim said:The heads do screw off, but I can't be ar5ed to change them every time I want to use it.
ban-all-sheds said:FFS.TheOriginalSlimJim said:The heads do screw off, but I can't be ar5ed to change them every time I want to use it.
LOL ... yup, done that a few times... Looked like Slimer had been in there!ban-all-sheds said:When you come to replace your brush head, and it therefore gets removed, have a root around inside the base with a cotton bud or something, and see what you find.....
ban-all-sheds said:Well - there you go then.
For reasons of basic hygiene, even if you aren't sharing the handle, you need to remove the head, and rinse inside it and then place it in the holder provided to drain and dry after each and every use, so given that you have to do that, there is no reason for not sharing the handle...
True - as well as being a lazy slob, TheOriginalSlimJim might be a dirty one as well.Gary0 said:You only need to remove the head if you want basic hygiene![]()
A few '00 mA, IIRC.Out of interest, what's the charging current for toothbrushes anyway ? Just a trickle I'd have thought.
mead said:Just wire in a double socket outlet, no problem its only a charging unit to be plugged in what harm will that do
Who says he can't?the_jinj said:mead said:Just wire in a double socket outlet, no problem its only a charging unit to be plugged in what harm will that do
Point is he can't as it's in a bathroom.....
