- Joined
- 7 Feb 2016
- Messages
- 13
- Reaction score
- 2
- Country
Hi Team,
I wonder if someone may be able to help with the following issue.
The Thermecon boiler is approximately 15 years and in the main performs well.
Last year we had a problem with the spark generation to fire the burner. On inspection the HT leads seem to be arcing and the spark wasn't always appearing at the electrodes. I managed to "fix" the problem by insulating the HT leads near the electrodes and this seemed to sort the issue.
Move on one year and the boiler failed to fire about a week ago. The symptoms were that on start up there didn't seem to be any sparking sound. On taking the burner off and quickly setting the boiler to run I could see that the was no spark being generated.
Move forward another two days and I have replaced the spark transformer, HT leads and what appeared to be the cause of the problem - the Electrode assembly. I think the insulation surrounding the two electrodes had broken down so much that it was shorting to earth which meant that there was no spark.
So, I thought I had sorted the problem. I put everything back together. Now when the boiler starts I hear the fan start, then the oil comes in and the spark kicks off. The fuel ignites and then immediately 5 or so seconds later, locks out.
Arh I thought. Had this before when the photo sensor was dirty. Took it out and it's as clean as a whistle. So I opened the burner hatch and saw one of the HT leads that I had replaced appeared to be covering the eye of the photo sensor. I was convinced that this was the issue. However, the same lockout problem results when I put it all back again.
So I took out the photo sensor and checked the resistance with a multi meter. This seems to register < 300 ohms in light so appears to be okay. I also let the boiler fire while the photo sensor was out and shone a bright light into it and still the lockout occurred.
So, to discount the possibility of the photo sensor causing the issue I wired, in parallel, a switch to short the terminals that the sensor is attached to. When the boiler fires I switch the switch so that there is effectively zero resistance but still the lockout occurs.
So now I am thinking it's either the control unit (Landis & Gyr / Siemens LOA24) or something else is causing the lockout out, but what?
I have even taken the control unit cover off and watched the gubbins inside the control unit. The bimetallic strip pulls across as expected on start up but the main solenoid on the right does not seem to energise. If during the firing process I physically push the solenoid contactor down then the boiler appears to continue to work as you would expect. On releasing the contactor the flame is lost but the oil pump is still running and I have to power off the boiler.
Now given all this, it seems to me that it's either a faulty control unit and at £55 a shot I am reluctant to replace just as a test, or something else other than the photo cell is not giving the feedback to the controller to allow combustion to continue.
Does anyone, from the symptoms described here know what the problem is?
From the spare parts I have purchased it appears that the burner is a Ecoflam Minor 1 or 4?
Any help would be greatly appreciated as it's cold!
AJ
AJ
