No banjos, I'm not made of moneyhave you used the swa earth nuts? I use them exclusively now rather than banjos and nuts
they are a bit pricey but for those glands not a lot, the 32mm I use are about £15 each for 20mm only a few pounds tight git. Saves a lot of work so pay for themselves. Also not keen on plastic blancs either, just my two penneth to help you out.No banjos, I'm not made of money
I agree but theres a lock on the doorAlso not keen on plastic blancs either, just my two penneth to help you out.
What I find ridiculous is having to use metal clad boards, then populate them with plastic breakers and plastic blancs. Hardly a fire barrier.I agree but theres a lock on the door![]()
It is when the doors shut.What I find ridiculous is having to use metal clad boards, then populate them with plastic breakers and plastic blancs. Hardly a fire barrier.
Goodnow coming out in a rash
hardly. huge gaps around the doors so not fire rated. Not knocking your job just stating how it is with our regs now and how contradictory it is.It is when the doors shut.
I knowIt is when the doors shut.
I agree with thatjust stating how it is with our regs now and how contradictory it is.
I was called out today to a lamp post internal fire. Because they run off 500A fuses they don't blow, just keep fizzing until we shut them down.You can't be too careful. I always remember how the Towering Inferno started.
Well he has to really as he creates most of them.Do you extinguish these fires yourselves, or do you get the fire brigade?
We cut the supply to stop it,Do you extinguish these fires yourselves, or do you get the fire brigade?
