- Joined
- 21 Jan 2017
- Messages
- 112
- Reaction score
- 2
- Country
Hi All,
Currently renovating an old wetroom.
1. Removed everything back to brick. Currently, Have stud battened the walls, insulated the spacing and am now ready to apply the tile backer board, however, before I apply the tile backer board. Should I cover the insulation and battens with a Polythene Vapour Barrier then after apply the backer board?
2. I know tanking is crucial, I will be tanking the washers and (tape/tank) joint lines betweens boards, corners etc... though should I leave it there? or should I just go and tank the whole wetroom backer boards? Bearing in mind the backer board are the perfect surface for tiling anyway and are waterproof. (Backerboard below)
3. The wetroom has a small privacy window that is top opening, around 600mm wide x 700mm Height. So I can open this after using the wetroom? or is it advisable to install an extractor. What would you do?
I assume taking these steps would ensure a watertight wetroom not allowing moisture to pass-through the backer boards, even vapour barrier as mould cannot grow on plastic. Therefore no mould growth or penetration to the wooden battens.
Thank you in advance for your answers.
