hi people windows 8 hasn't lived up to the hype it showed on commercials.
the main problem people are having is wifi problems which keeps going to a limited connection where the wireless icon in the task bar has a yellow triangle with a ! in it and it also says limited no internet access.
what microsoft hasn't told you is that the problem is with the wireless adapter there is a option in the wireless task manager that says turn of this device when not in use.
heres how to sort that problem out...
1, place your pointer on the wireless icon in your task bar and right click on it
2, select the open network and sharing option
3, when you've chosen that option on the right hand side it should say your wifi ssid click on that and it should open the wireless status box
4, in wifi status box click properties the one at the bottom and that should bring up wireless properties
5, click on configure and that will open a box that says wireless network adapter settings
6, choose the power management option
7, there is an option that says allow the computer to turn off this device to save power
8, click the box so the tick is not visible in other words de select that option
9, close the the open windows
10 , restart the computer and hey presto no more limited signs but you must restart the pc
now enjoy uninterrupted internet access
thank you thought id share this with you as certain IP providers charge £50 to send an engineer out
