It's a bit disconcerting that a firm like Worcester Bosch doesn't understand the concept of latent heat. It's not latent heat, residual heat would be a better way to describe it.Did some investigating tonight. Temperature on the wave set to 19 degrees.
The Wave turned the boiler flame out at 18.2 degrees (set temp 19) and according to Worchester Bosch will then continue to run the pump using the boilers latent heat to continue warming the room up untill the set temp is reached. Only problem with this idea is that as it is still 0.9 degree short of the set temp and the set temp is never reached so the pump continually runs untill the actual temp drops low enough for the boiler to re fire. This then repeats all day unless by some miracle the set temp is reached, maybe as the day warms up.
Also just notice that despite the wave reading 18.9 degrees (0.1 degree below set temp) the pump has just restarted but the bolier hasn't lit, so now we have a running pump pumping cold water round the system.
I think the complaint that the pump runs all the the time is not exactly true and it is the above scenario that is happening.
In my view this has made what was a pretty good product absolutely useless as my set temp is never reached.
As it is coming into summer it is not such a big deal at the moment but if the next software update does not fix this silly idea of using latenet heat and continually running the pump I will be demanding a replacement from Worcester Bosch.
But if you've found that residual heat raises the room temp by an additional 0.7degC, you might try altering the 18.2 to 18.3 or somewhat higher to make sure. At least as a stopgap while you try to get some sense out of WB.
