I wonder if this complies with all of the standards that it should to be sold for use as described?
There's more to making a cable which complies with the requisite BS standards than just adding a bit of sheathing and hoping it complies.The article answers that question with
The cable is supplied in single insulated form. For installation purposes the cable must be double insulated, which can be provided at additional cost.
4mm diameter means a csa of 12.6mm².and also says
• Number of conductors - 16 (eight Live & eight Neutral, colour coded brown & blue)
Total live or neutral conductor diameter – 4mm
Is that equivalent to 4mm diameter solid copper or is it a 4mm diameter of copper strands with air spaces between them.
some of the things I have heard would amaze you.
Here is another example, and nothing to do with Mr Andrews either:
http://www.amazon.com/gp/product/B000I1X6PM/ref=cm_cr_pr_product_top
Read the product description and check out some of the reviews. And the customer provided images.
Just to clarify - this product is an ethernet cable. 1.5m long. Just like the ones used to connect a computer to a switch or router. They can be purchased for less than £1.
This cable does allow for incredible sound. However, I believe a possible side-effect from the use of this cable has not been noted by the manufacturers. Upon playing Prince's "Kiss" my speakers ... how should I put this? ... Well, I think they ... climaxed.
That's not the end of it. Oh, no. My stereo system is now sentient. And horny. Not one of my other appliances has warranty coverage for ... well ... the kind of 'damage' they are currently receiving.
I'd just unplug the darn thing, but it's developed an ability to arc pure energy when it feels threatened. It took two scorched electricians to figure that out. And, yes, I've already tried flipping the breaker switch. Doesn't work. The power won't go out. I don't understand how the hell it pulled that off.
Please, if anyone has any tips or advice, I'm getting desperate. My living room is some kind of sick, mechanical sex den and it's really freaking me out.
I would suggest you guys lay off Russ Andrews
I was under the impresison that it had a different pair arrangement than an ethernet cable from pictures i've seen. Dunno enough about the application to know if that matters or not.Just to clarify - this product is an ethernet cable. 1.5m long. Just like the ones used to connect a computer to a switch or router. They can be purchased for less than £1.
