How are you going to test that you have an adequate supply?
How are you going to determine whether you have adequate ventilation?
Perhaps you should get a monkey in to do it.
I'll put both ovens and all 8 rings on the cooker on full blast at the same time as the fire (and any other gas appliances using the same 15mm feed). If they burn away nicely then I'll assume the supply is adequate.
how will you test for leaks? the good old corrosive fairy liquid. honestly people like you get me so annoyed you cant put a price on life!!!
No-one else, however, has commented on the open flue appliance/extractor fan in the same room issue which is where I was comming from. I have an interest in understanding what you can & cant do, albeit not on a gas appliances, so comments would be much appreciated.
Troll alert!
Why rise to the bait, its a blatent wind up
