Extract from the installation instructions...
IMPORTANT: If this product is installed using a Blagdon Powersafe armoured garden power supply fitted
with a flexible lead to a three pin plug, in conjunction with a circuit breaker as recommended in the
installation guide. It would not therefore be deemed to be a permanent part of the house wiring and
would not fall within the scope of Part P of the building regulations. However if the product is wired
directly into a fixed wiring spur, it will fall under part P of the building regulations and must be installed by
a qualified electrician or in consultation with a building control officer.
Clearly the manufacturers and their lawyers seem to think when fitted as suggested it is not notifiable under Part P.
So that is the end of this story
