noseall
Bosch huh? Well, as for it lasting twice as long as my "antique", well I didn't know the b and d would last for over 20 years, so your making a VERY bold statement that the Bosh will last over 40 years. I've seen plenty of reviews, that Bosch are no longer as good as their name, and plenty of purchasers who talk of stripped gears. But you may be right for all I know, and I wont disagree with you that SDS is VERY good for its hammer function.
However, ---- I don't want an SDS, I want a compact. I want a drill with the same spec as my "antique". I want to repair this one, is that ok with you? Or do you have shares in Bosch or are you a salesman for them?
seaangler
Thanks, yes you might well be right. I looked again at the P2271. It lists 2 types. numbers 3 and 4.
Even though neither have the hammer or gear selector, in the SAME location, otherwise I agree with you, the rest does look very much the same.
The problem is though, that I dont know enough about the electrical specs for either the P2271, or my own (i dont have my model number), to be certain that the field winding is the same.
That's why I was hoping to at least find the same external physical layout for the drill as a guide that the internals would be the same too.
But I am going to assume that you are right and search for the field windings for the P2271 as you suggest, and see if I can come up with a part number. maybe I can match that to a part number on my own drill. I'll strip it today sometime and take a look.
And it would be very surprising if the same winding wasn't used in a variety of models, so hopefully it will be available somewhere.
Update
This is a link to a drill brand called Elu. B and d took em over according to a b and d techicnician.
http://www.mtmc.co.uk/Spare-Parts/E...2705038-12705121-12705302-12709142-22083.aspx
It looks just the same as the b and d P2271, and the field for a 240v is available.
The part numbers for both are virtually the same, -- (except the end digit---) so I will have to check further
What do you think?
noseall
seaangler
Update
What do you think?
