But they have been put right. Some were wrong to begin with.Where did it all go wrong?![]()
Look a tad closer at the above diagram and then come back to me after you have re-read what you originally stated..There you go. Look at `J`. LOL! Full modulation of the burner, injecting the correct level of heat into a house, controlled by variable acting boiler stat and `room thermostat` and no electrics at all. You can tell all the GasShark registered in the Combustion Chamber thread all about it.
He is trying to lecture us now - on a topic he knows sweet nothing about.Look a tad closer at the above diagram and then come back to me after you have re-read what you originally stated..![]()
Bernard, the last device on the weep line was a safety device in case the wind up clock failed. Not all domestic boilers had this. I never heard of a boiler having an explosion, but the device to me was essential. A snap-acting high limit thermostat on the boiler could also be in the line. I recall the governors were made by Jeavons, the thermocouple valve by Honeywell and I think the relay valve and all variable action stats made by I `think` by Powell Duffryn, that name comes to mind. The timeclock was made by Horstman, similar to those in street gas lights.did gas weep pipes go from the boiler to room thermostat and then continue on to a timer or manual ON-OFF control before delivering the weeping gas to the weep burner next to the pilot light. Apparently they did. A series of controls along the weep pipe. The last weep control before the weep burner would have been kept open only by heat from the pilot flame ( bi-metal strip ) to ensure there was no weep flow if the pilot was not lit and hence no main burner flow..
By the name of Steelmasons I would guess.Anyone remember that idiot who posted on here not so long ago regarding, iirc, help with his daughters noisy boiler?
Then ended up, in a delusional fashion, insulting all the regular posters on here in an increasingly aggressive manner?
His signature pic had an ugly s*d with red hair in it - can't recall his name atm.
Wonder if he's returned under a different moniker?
So that'll be why I have never fitted one... So how many have you fitted?Engineers, not servicemen, do not fit them. To drill some holes and hang a box on a wall is no feat of construction genius. LOL The Ferroli is so simple to fit, a monkey could fit it.
I am not a monkey.So that'll be why I have never fitted one... So how many have you fitted?
But it seems that you suggest that the guys who fit Ferrolis are..I am not a monkey.
But he said nothing about training...No.... what he is saying ( as I read it ) is that a monkey could be trained to fit one.
Gorillas aren't monkeys... They are Apes.It would have to be a trained monkey since an untrained monkey could not read the installation manua l.![]()
Hang on. there is a gorilla at the bus stop reading War and Peace while waiting for the next bus.
Ah... no can't be, he is holding the book upside down.
