I'm not quite sure what you are querying.
Yes, but that's not going to be the case, is it?
You could connect the 4mm² directly to the MCB and have a radial with as many sockets as you wished.
Take these two circuits:
The left is as people are suggesting - extend the ring - it happens that all the sockets are on the short leg.
The right - connect the two 2.5mm² - or use 4mm² - cables and make them parallel. Is that detrimental?
In this case, with the sockets on the shorter leg, it would actually better the balance as the long leg is now shorter.
Obviously, it could be the other way round but it has been agreed that balancing should be considered.
When a 13A FCU is inserted to cover a multi-socket spur, do you think this is to protect the spur cable or the ring?
If the spur, as it must be, then it could be 25A if such were available, so why not increase the cable size?
