I suspect that those who want to argue would only stop arguing if you could indicate what creates a requirement for a CH system to have a ('dedicated') single point of isolation. As far as I am aware, BS7671 does not require anything (other than the installation as a whole) to have a single point of isolation, so you'd probably have to look elsewhere.If you consider that the FCU to a boiler is meant to be the single point of isolation for the central heating system which includes the boiler, ancillary wiring, pump, room thermostat etc - often wired in 0.75mm² or 1mm² then perhaps this argument can go away.
As I and others have said, it's all a bit moot, since I personally don't recall having seen any CH in recent times that was not supplied via by a BS1363 socket/plug or FCU (hence a BS1362 fuse). The argument has really all been about whether manufacturers should be 'requiring' something that at least some people regard as 'unnecessary' (even if it's virtually always done!).
