since I personally don't recall having seen any CH in recent times that was not supplied via by a BS1363 socket/plug or FCU (hence a BS1362 fuse).
Kind Regards, John
I have. In mainland Europe, supplied via a Schuko plug and socket on a 16a MCB.
Kind Regards, John
Even you should understand that I was obviously talking about the UK. You wont find many "BS1363 sockets/plugs or FCUs" in mainland Europe, but (my point) nor will you usually find a boiler or CH system in the UK which is not supplied through such an accessory.I have. In mainland Europe, supplied via a Schuko plug and socket on a 16a MCB.
He does.Even you should understand that I was obviously talking about the UK.
Kind Regards, John
Exactly. As was said a long time ago in this thread, the only exception (to supplying it via BS1363 accessory with BS1362 fuse) would be to supply it off a lighting circuit, and goodness know what you'd have to say about thatTrue, but surely the reason is they are invariably spurred off a ring final protected at 32 amps.
Kind Regards, John
An old fashioned wax capsule TRV will do that as well unless it's one of the few models with a real "absolutely off" setting. That's why if you remove a radiator (which is NOT the same thing as working on something that needs the electricity supply isolated) then you should be either fitting blanking plugs to the open valve ports; OR fitting a "decorators cap" in place of the TRV head to physically hold the valve shut.So if after removing a radiator the non isolated electronic TRV turns on and allows rusty water to escape that's OK?
Really ? Ours is on a 16A radial (with an FCU on the end with 3A fuse fitted), quite a lot are similarly done. It'll be getting a socket fitted at some point to make it easy to unplug the boiler and supply it from an battery & inverter if/when the power is off for any reason.True, but surely the reason is they are invariably spurred off a ring final protected at 32 amps.
Yes, I'm sure that a good few are like that, but I think you will agree that most boilers are probably fed 9via an FCU) from a 32A circuit. This is really what this discussion is about ... supplying a boiler through a 13A fuse (in plug or FCU) is the nearest easily-implemented UK equivalent of the situation in mainland Europe in which the boiler would usually/often be connected to a 16A circuit with no additional fusing - hence the discussion as to why (only in the UK) it should be a 3A fuse. In your case, of course, you have the same situation as in europe, so the question would be whether you really need any fusing (in addition to the 16A OPD) at all.Really ? Ours is on a 16A radial (with an FCU on the end with 3A fuse fitted), quite a lot are similarly done.
Yes, I do similarly. My entire CH system (not just the boiler) is fed via a plug (with a 3A fuse), which I can shift into my genny supply if/when needed.It'll be getting a socket fitted at some point to make it easy to unplug the boiler and supply it from an battery & inverter if/when the power is off for any reason.
It might (we still don't know) be a gas regulation.This is really what this discussion is about ... supplying a boiler through a 13A fuse (in plug or FCU) is the nearest easily-implemented UK equivalent of the situation in mainland Europe in which the boiler would usually/often be connected to a 16A circuit with no additional fusing - hence the discussion as to why (only in the UK) it should be a 3A fuse.
Well volunteered - let us know when you've found out either wayIt might (we still don't know) be a gas regulation.
To what end?Yes, you keep saying that but surely the principle can be discussed.
