My boiler - a 15 year old Ideal FF350 - has been starting to play up:
When it starts up the pilot light will ignite with a loud click, then take a long time to start the main burners, before switching off after 90 seconds or so. After another 90 seconds the sequence will start again and again until the timer switches it off (the boiler will go on and off like this for maybe 10+ times in 20 minutes).
Is it likely that the solenoid valve is playing up, or a problem with the circuit board? If the valve, for the Ideal boilers, I'm not sure if it requires the "gas valve" or the "gas valve kit classic" (see number 17 on this plumbase page for the boiler). I've been told that if it turns out not to be the valve the PCB will then need to be fixed instead.
I'm just trying to get an ideal of cost more than anything, especially as this is one of many elusive plumbing problems I seem to have at the moment!
Thanks in advance
Moderator's note
This site does not support DIY gas and posts giving advice on gas work, or encouraging or suggesting it, may be deleted. However, posts are not routinely monitored, so no work should be done as a result of seeing anything on the site.
Read more: https://www.diynot.com/diy/threads/diy-gas.8090/#ixzz5RjYkglm4
Thanks in advance
Moderator's note
