- Joined
- 12 Apr 2020
- Messages
- 466
- Reaction score
- 0
- Country
What does it do outside ?
It joins with the waste from the boiler and goes along the side of the house and attaches to the main waste down pipe
Sounds like an awful long run of pipe, and a load of hassle for no real gain.
So where it exits the wall with an elbow, could you change that for a T with an access cap so you could push a wire/drainsnake up the basin run ?It joins with the waste from the boiler and goes along the side of the house and attaches to the main waste down pipe
Maybe he means for when it does bung up.Sorry I don't understand! I've never done any plumbing beforeWhats a drain snake? The drain isn't blocked, I just am wondering how to get a fall on it, or possibly re-route it a better way
Whichever way you do it..You cannot have a horizontal waste pipe a few metres long.
A couple of pictures of the basin waste and toilet waste and how they relate to each other in the bathroom would help.
Ahh, that's helpful (the pics). Is that grey pipe in the wall for the loo? If yes then you can join to that (of course the pipe will be visible). Not sure that cutting into those studs will be a great idea.....
whats going on the floor for the sink, does it have a plinth ? If so then you have the height of the plinth , before it hits the bottom of a cupboard
Also wheres the New Toilet outlet running too and water for Cistern
Pipe work could go back to the Studs
I did that in our bathroom/combined ensuite partition stud wall - to get the most space and minimal boxing in
