Hello all!
During lockdown in April we moved into a new house and on day 1 found a gas leak which required a new boiler system. Our options were limited due to full lockdown so we got in touch with the closest boiler installation guy we could find, willing to work during the lockdown.
Long story short, they did a decent enough job but there were a few leaky pipes (both copper leading into boiler and waste leading out of boiler). As a pretty competent DIYer I fixed these myself - I initially told the plumber about the leaks (he came and fixed one, I fixed subsequent leaks) and he said it's normal when switching from tank system to combi boiler - not sure how true this is.
Anyway, flash forward to today and I discovered water dripping out the bottom of the actual boiler. Probably not a great sign, right? I've located the leak to the exhaust flue at the top of the boiler - pictures attached. I initially tried to prevent water leaking by wrapping the joints in plumbers tape but this hasn't worked.
I don't really want to have anyone in the house unnecessarily (COVID) and this plumber is obviously a bit of a cowboy, so I'd prefer to not have him fix it. In normal times I would be tempted to just pay a good plumber to come in, check everything over and fix any bodge jobs, but we're not in normal times. So is this something I can fix myself? If so, what do I do?
Any help, advice etc is very much appreciated!
Cheers
Auric
Edit: Boiler is Vaillant eco TEC plus 938
Cheers
Auric
