Fuse panel hot unit, smell in corridor below?
3ph do tend to follow your layout but bigger versions can vary, one 2KA I saw had 3 individual N terminals but only big enough for (say) a 10mm² wire. I haven't such a big meter for a long while though.
When you say "3 individual N terminals", do you actually mean 6 (3 'in' and 3 'out')?
No, one Neutral terminal per phase, only used as a reference point. Bigger meters like that don't carry the neutral current too.
Has anyone come up with this thought?
Propah Charlie has probly nodded off by now!
I fear you're probably right!
@Propah Charlie : if you're still around, apologies for the diversion that has arisen, but it would be good if you could provide another photo of the area around the meter and fuseholder, taken 'straight on' so that we can see what is between the fuseholder and the meter, and what is to the left of the fuseholder. Thanks.
Fair enough - but if it's "only used as a reference point", then what's the point in having three - are the all wired to the same place, with three conductors effectively in parallel?
I don't think so, but I think that's pretty unlikley - although not impossible.
Why unlikely? Much depends on what the guy has on the van at the time and all the old C/O's were double fused.
Not 'unlikely' in terms of what might have been done but, rather, in my view, 'unlikely' in terms of what I can (and cannot) see in the photo. However, this is all just speculation.
Perhaps I could have used the word independant?
Are you saying that the three N terminals were not connected together? If so, what would one connect each of them to?
Electrically (but not mechanically) there are effectively 3 single phase meters in the one enclosure.
Agreed the view is difficult, my opinion is there seems to be something hiding behind the meter.
Happy to be wrong though.
Fair enough - but I still don't really understand "to what" one would connect each of these three 'independent neutral terminals'.
Well for starters it could depend on what's available.
