D
Deleted member 294929
I know that you and others like you are among us.
I haven't gone through each and every photo but I think you're out on a limb there. As others have pointed out, they're verified (and Include coordinates so you can probably find them on satellite photos).What a stupid way of thinking. They show you photo's of 600 tanks & yet you give no consideration that it might be 100 MBT's snapped from 6 different angles.
If they were really getting the 'kicking' that you are being told they're getting, then the conflict would be moving in a much different direction.
That link I put up says the Ukranians are using guerilla style tactics, nibbling away, then the Ru's launch masses of missiles on some Ukranian trenches and obliterate them
There's a good RUSI summary of the issues experienced with the Russian 72 and successors. They've got excellent frontal armour but poorer side armour (all tanks do but most Western tanks are proportionally tougher). This means they're more vulnerable to man portable weapons from the sides, especially if they're unsupported by infantry as happened their botched invasion attempt.I read that there are geeks out there analysing photos and did come up with an extremely big number, but they have an enormous number, stored. Something over 12,000.
Added to the tank losses, is the knowledge that they have a nasty habit of losing their turrets when ammo inside is set off, as learned in the Iraq war. That kills the crew, and it takes a long time to train a new unenthusiastic crew.
They've changed tactics to lose fewer, and they are inching forwards down Donbas way.
Ukrainian positions are not being obliterated, in fact UA are taking back significant areas around Kharkiv.
The "obliterated" quote came from the Ukranian side. Where the russkies bring up some of their GRAD multiple launchers or another whose name I forget, they're pretty devastating. They only have enough for very selected use, clearly.Ukrainian forces are playing the best strategy: they are choosing to give up ground rather than hold and suffer huge casualties, but UA are picking off Russian targets as and when they can….and causing significant losses.
https://www.understandingwar.org/backgrounder/russian-offensive-campaign-assessment-april-30
The tendency of the tanks to cook off when hit is spectacular but it doesn't really matter much, anything that penetrates the armour of a tank typically kills the crew and wrecks the vehicle.
The bonus of the autoloader is reduced manning requirements, a smaller lighter cheaper vehicle and a lower profile.
Now they're using them as intended by doctrine, supported by artillery and infantry their losses will be slower.
A good, honest summary. I can't wait to watch clips of the parade in Moscow.
Strategic experts are saying Russia is failing massively.That's just one region, where the Ru's said they were retracting.
Not really a summary of the war.
The Ru s said they were going to withdraw from some areas like Kharkiv, which I daresay the other side would report as a successful counter attack
