- Joined
- 11 Jan 2004
- Messages
- 46,243
- Reaction score
- 3,660
- Country
Cabling is not rubber.
Did a quick IR at ceiling rose and got a squeak over 1Meg.
I suspect he has:
tested the fixing screws at the hall switch and got nothing, so assumed no earth.
tested the IR without unplugging appliances or removing lamps and got low readings (which you would expect) and called it faulty wiring.
He apparently took less than an hour and charged a ton fifty.
I suspect he has:
