I'm having a EV charger installed, and it optionally can use ethernet.
The manual has this to say about it:
The diameter of that cutout is about 20mm - but I can't find a gland that would both be able to fit an RJ45 plug, which is 12.2mm (even without clip), while also being narrow enough for the cable, which is 4.8mm. The smallest one that would work is called a "PG19" apparently, but the smallest cable size it fits is 12mm, leaving just over 7mm gap.
I could probably leave this to the electrician, but I think he usually only does the Wifi option. I thus want to pre-order any such gland so it's ready on the day.
I really don't want to terminate a solid-core cable inside (which would be a nightmare for maintenance/replacement), so ideally just want to use a short patch cable.
What are the options here? I've heard some people use electrical tape to bulk-up the diameter of the cable, but are there other options?
