Why have you turned your attention to what started the fire, rather than the more dangerous issue ate hand - what spread the fire?I see Notch is back oh no Nosey. Now let's see what caused Grenfell was it the cladding or the fire started in a fridge? Come on you smart people?
Fires will always start, for various reasons.Don't be silly now if the fire had not started - go on you fill in the blanks.
The fridge may have been the initial cause.I see Notch is back oh no Nosey. Now let's see what caused Grenfell was it the cladding or the fire started in a fridge? Come on you smart people?
Such as ?I don't think anyone is suggesting that the fatalities were not caused by the exterior cladding and how it was allowed to be installed. (there is the hint) It's not the construction but how it was allowed is the issue.
Fires start for many issues and acerated due to interior furnishings. This should not lead to compartmental escape as designed for tower blocks but trying to pin the blame solely on cladding ignore some more fundamental issues.
And the spread was the cladding. The fire spread on the outside of the building, not the inside.How a fundamental design feature of compartmental containment to each habitable space was allowed to be compromised in the design phase for the building up grade? The whole fire safety principle of tower blocks was by default fires would be limited to each unit rather than spread across the building.
The design assumed, wrongly that the cladding was not flammable and that it would not actively enable fire to spread.And this design feature when the blocks were build was then ignored? Sorry don't see where you are going with this.
The individual flats were self contained fire safe compartments, hence why the instruction to stay in place was given.And this design feature when the blocks were build was then ignored? Sorry don't see where you are going with this.
No.I see Notch is back oh no Nosey. Now let's see what caused Grenfell was it the cladding or the fire started in a fridge? Come on you smart people?
