- Joined
- 7 Nov 2023
- Messages
- 19,352
- Reaction score
- 12,084
- Country
yes the earth we put in is only to protect the light in normal circumstances, during a crash it just gets ripped out. We do actually have a new safer method when we put new lights in, these are called snatch leads and are designed to disconnect safely. However these are new and we only install them in high collision areas due to their costsAs you would know, a 10mm bonding conductor is usually connected to the MET just inside the door opening. Surelyt the 'bond' is there to negate any difference in potential between the DNO earth and the column in the ground under fault conditions.
