Yes it is.
Great example of intelligent debate.
What is asserted without evidence can be dismissed without evidence.
I have demonstrated the falsity of all the facts he provided to support his false claims.
There was none.
Yes it is.
but the assignee has none. Being given an option is a choice, assigning leaves no choiceThe assigner has a choice.
To take this a bit further, if one door has a no exit sign above it then, in reality, there is no choice at all. The exit door is the exit door, it isn't "assigned" an exit door.If you are in a room, with two exits, you choose which exit to use.
If you are a labourer, you can be assigned to ditch digging, rubble shifting or waste burning, it is a choice made by the person assigning the task. He can do it at whim.If you are assigned a task then you have no choice in the matter as that task has been assigned to you
Nonsense. The sex of the baby decides that.Whoever is in attendance at the birth, chooses which sex to record,
Yes. I was really talking about the assigner.but the assignee has none. Being given an option is a choice, assigning leaves no choice
Why do you keep assigning yourself different accounts?And there are never mistakes in the medical world?
If you are in a room, with two exits, you choose which exit to use. Which exit you chose is then recorded.
Whoever is in attendance at the birth, chooses which sex to record, and there is only a choice of this or that.
lol I suppiose soIf you are a labourer, you can be assigned to ditch digging, rubble shifting or waste burning, it is a choice made by the person assigning the task. He can do it at whim.
If you are a boy baby, nobody can assign to you the identity of a kangaroo, or a kitten..
I was talking about the assigneeYes. I was really talking about the assigner.
exactlyOpened a new one in anticipation of the 'sleeper' account he's recently started using being rumbled.
exactly
and still is, he is now a martyrThere was only one Pete01.
No, it isn't assigning anything. It is simply recording what is dangling in front of them, or not.When a sex ia ssigned, it is the person that makes the choice that is doing the assigning.
