- Joined
- 26 Nov 2015
- Messages
- 24
- Reaction score
- 6
- Country
Hi, I recently had a gas boiler replaced in a 2nd floor flat. In discussions with the company afterwards, I found out that they had to drill a new flue hole (I wasn't there when the work was being done - it didn't seem like they would have taken the initiative to tell me!). This hadn't been planned - the possibility that this would be necessary hadn't been discussed beforehand. From the outside, the old flue hole appears open (see image) - they've not told me yet if there was any sealing done on the inside. The hole is covered over by the boiler, so it can't be seen from the inside. The cupboard where the boiler was installed is a tight space with only just enough clearance, which is why I think the position of the flue needed to be changed to fit the new boiler. I'm also going to have to discuss this with my freeholder, as I think their permission would normally be needed beforehand for changing a flue hole.
I was wondering is it acceptable for the old flue hole to have been left like this? And is it reasonable for the installers not to have raised beforehand that the need to move the flue hole was a possibility given the amount of available space, given there is not generally freedom to drill through external walls in a leasehold flat? Is it urgent to get the hole repaired, or is it not a big deal if it's left like this for a few weeks? Does anyone here know what would be the most cost-effective approach to getting the hole repaired?
Thanks very much to anyone who can help.
