- Joined
- 26 Nov 2015
- Messages
- 28
- Reaction score
- 8
- Country
Ah OK, sorry for misunderstanding. I don't know if that pipe in the bottom right is new - I don't have photos of that wall and don't remember what was there before. I believe the previous boiler was non-condensing - it was a Ferroli F30, plausibly from 2004 when I think the flat was built, and my EPC from when I moved in says the flat would benefit from having a condensing boiler installed. Is it likely to be a newly installed condensate drain pipe then? And it ought to have been connected into another drain?
I'm not able to measure the distance from the window to the flue right now - I'm away from the flat - but will have it checked.
I think I found the manual you meant now - very useful, thanks!
It only came out in email discussions afterwards about another issue that the flue had been repositioned, and they mentioned none of the other issues raised here, so I don't think they were planning to come back to it!
Several Vaillant boilers including the ecofit
It looks as if the installer, only had access from the inside, so did all the work from inside, completely ignoring the outside finishing. Perhaps the intention is to return later, to complete the job?
