Looks like it - although sometimes the wire end snaps inside the insulation.
Does any wire feel extra bendy on the end?
it just depends on which order I start off with to get them to work.
No I had this the once, the carpenter had put a screw through the cable, it broke just the black...Screwed in too tightly do you mean?
What will that prove?A quick test will be to remove this brown and grey and link them together
which should light the lamps (without switches making any difference)
errrrr... it's called faultfinding and a good first step to help talk a DIYer through the problem.What will that prove?
But the light works - so it's bound to light when those two wires are connected.errrrr... it's called faultfinding and a good first step to help talk a DIYer through the problem.
I knew itI have the answer.
I have replaced the left switch with a new one and now everything is perfect.
Thanks all
There was a possibility it didn't light, hence my start into faultfinding, which may haveremoved the need to go out and buy a replacement.But the light works - so it's bound to light when those two wires are connected.
Sound adviceI told him to buy a meter.
